Motor swap options for '90 240sx...
mva801
Hello all. I have a '90 240 sx coupe, and am starting to explore motor swap options. From what I've heard around town, its a little tougher to swap the sr20 into the SOHC cars, as they don't have the mounting points for the intake, ecu, wiring harness, or intercooler like the 91 and up s13's. Is this true? How much more difficult is an sr20 swap in the 89-90 s13's? Also what is involved with swapping in a turbo KA24DE into the single cam cars? My target horsepower mark is between 250 and 280 at the wheels, and I'm pretty sure i can get that with a properly built turbo KA24DE. will that be easier and less expensive? Any advice is appreciated!
89_240Coupe
Car: 89 coupe exhaust, header, intake, coils, soon KA-te
mva801 wrote:Hello all. I have a '90 240 sx coupe, and am starting to explore motor swap options. From what I've heard around town, its a little tougher to swap the sr20 into the SOHC cars, as they don't have the mounting points for the intake, ecu, wiring harness, or intercooler like the 91 and up s13's. Is this true? How much more difficult is an sr20 swap in the 89-90 s13's? Also what is involved with swapping in a turbo KA24DE into the single cam cars? My target horsepower mark is between 250 and 280 at the wheels, and I'm pretty sure i can get that with a properly built turbo KA24DE. will that be easier and less expensive? Any advice is appreciated!
If your looking for that hp range why not just turbo your ka24e? I mean if you piece it together, its probably your cheapest and easiest solution.. I mean sure the de, and sr breathe better, but you only need to worry about that if you plan on building a super engine... Why put a 2.0 engine in your car when you already have a 2.4?? You dont see honda guys and toyota guys throwing smaller engines in there cars do you??? lots of people on these forums have 0 love for the ka, especially the kae, but do some research and you will find out, its not that bad of an engine
Modified by 89_240Coupe at 6:04 PM 6/8/2006
180fan
Car: 89 fastback
for the 90 you have the following bolt on options. ka24de, and the sr20det. They're bolt ins and some wiring.
240_DRIFT
Car: NISSAN 240sx
there are lots of engines that you can swap on a 240 some you can just drop in and sone need seriouse custon work since your car has a sohc engine you can simply swap it to the KA24DE-T 155hp then theres other japanese enginesCA18DET 173hp but its a little 1.8LSR20DET 203hp maby the best choiseRB20DET 207hp the simplest way to say you have a skyline motorRB25DET 247hpRB26DET 318hp the most expensive $7-8,0002JZ-GTE 320VG30DETT 300HPand others
