motor swap compatibility thread
spacedout
quick question:
which motors will swap directly into a 91 240sx? engine codes please!
i ask this because i found a 240sx with a blown motor and i need to find a motor if i am going to buy it.
1991S13
Car: '91 240sx Coupe, '00 QX4 4x4, '02 Sentra Spec V
Search and you will find which are easiest, you may even find a few writeups on how exactly to do it.
Of course the easiest is going to be a KA24DE, or KA24E. SR20DET is the most common, but there is also the CA18, RB20, RB25, RB26, etc...or be wild like Aries and throw in a LS1.
Sockington
1991S13 wrote:Search and you will find which are easiest, you may even find a few writeups on how exactly to do it.
Give me some more time and you can add the 2.3Turbo Ford (Lima) to that pile!
89 240 SOHC
Car: 1990 Micra S13....Micra with S13 Seats and other S13 accents to follow
Time....you only need 7 hours if you have all the parts....well maybe more cause you're prolly going EFI so we'll say 12 hours
