blazin, im going to help you. first things first, take your budget into account...then figure in engine cost for each motorset. then time and or money for wiring. then figure in for all the bits and pieces that go along with it, now double that.
you should have already worked the list down and please know that the information you have in the first post is straight silly.
blazin240sx wrote:he did a 2jz swap in his s13 and told me his story when he got his and 2jz kills rb26.
neither one "kills" the other its how you build them, both are capable of astronomical hp numbers. so that famous guy...is biased and his comment isnt based on fact.
blazin240sx wrote: i know a sr20 wont be able to keep up with certain cars.
wrong. its the diff between stock and built on both counts. a simple built sr20det is capable enough...and they have been built to insane levels over the years. so throw that mentality out the window right now.
now, i will give you some advice...dont bother with an rb20...yeah its a turbo straight 6 and its cool. but why bother when an sr can do the same thing and easier to get parts and tech help with.
if you are hell bent on an rb, stick with the rb25.
if i were you i would rebuild the stock KA for boost and go from there, if you are bent on a swap go with an sr20det.
