motor starting problem please help!!!
SrS13
Car: 1990 Fastback, 1993 Convertible Coupe
We had to remove my CAS in order to take out a bolt that broke.
To remove it I set the crank at TDC and the CAS slipped right out. When I re-installed it I set the CAS with the yellow mark aligned with the outside mark of the CAS, and slipped it back in.
Now when I try to turn on the car it cranks perfectly but wont catch on. Please help what did I do wrong???:help :help :help :help
quiksilvia
Car: 95 s14 se
did u unplug something and not put it back? wither that or the cas is bad...try unlpugging the batt for like 15 mins and see if that helps
NEED4BOOST
check your fuel pump fuse...is the fuel pump priming when you turn the key to accs?
curbsurfer
i had a motor with a cas that was just thrown in , not lined up at all. it still started up , it just ran like crap. so unless you didnt plug it in it should still start or at least pop in the exhaust.
SrS13
today I set the crank at TDC and placed the CAS in, I turned it about 1/2 a turn to the right and the engine started it wasnt at correct timing but it the car was on.
what does that mean????
