:::motor spec question:::
evotech240sx
Car: 92 240sx fastback
if i were to add some forged racing pistions. what am i suppose to do with n-e other addition mods to make it all worth it. i already know about the basic but when i comes to the internal stuff. im not too sure on what to do.
Hijacker
Car: '92 240sx Convertible
'94 F-150
if you add forged innards to your engine, they don't really do anything unless you bump compression ratios around. A lower CR will yield less power, and a higher CR will yield more power. If you add forged pistons and rods to an engine, you're either going to be adding a turbo to the car, or you'll be running a very high CR (11:1 or 12:1). Forged components are just there to help hold power as opposed to help make it.
