motor skipen
Nissan 350z / Nissan 370z general community discussion forum
BAD04
i have a 04 350z,engine skips,service eng, light is on,had a guy to run the code said it was cyl, misfire any ideas
ZedHead
Car: 03 Track
change the plugs.......
what code did it throw?
Modified by ZedHead at 2:16 PM 5/7/2009
xjmxstac
Car: 2003 nissan 350z track edition
Random/Multiple cylinder misfire, or was it a specific hole?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
ZedHead wrote:change the plugs and wires
roflmao, the Z33, like the Z32 is COP, which means no plug wires ro distributor
ZedHead
Car: 03 Track
ha right.... i knew that....
BAD04
#1 cyl, misfire.got new plugs in it 2 months ago,may be the coil pack going bad what u think
DR350Z
Car: 2007 Nissan 350Z
Typically, you're either looking at bad gas or a component in the ignition system that is going bad. Does it ever run smooth or is it always missing? I'd find it strange that a COP would go bad, but I wouldn't discount that possibility either.
It wouldn't hurt to bring it through a Nissan dealer or dealer alternative for their opinion (they don't have to do the work).
BAD04
not all the time,it sarts spudering,i can rev the engine high and it clears up for a moment
BAD04
about two months ago the mass air gave a code,cleaned it,it done ok,
xjmxstac
did you check compression on that hole?
BAD04
ok got it fixed,thx for the info,changed the coil on #1 cyl runs great thx again,
Return to “350z / 370z Discussion”
