skillzilla »
https://forums.nicoclub.com/skillzilla-u17041.html
Mon Jul 09, 2007 3:55 pm
Are you losing coolant? Does it heat up when accesories (AC especially) is being used? How new is the water pump? Does it heat up only at idle or when in motion/higher revs also? Do you have all your ducting still intact? What else do you have controlling your fans?
Really there are only 3 reasons a car will overhaeat:
1) Air in water jackets. Make sure you dont have ANY air at all in the engine or radiator hoses, etc. As air gets trapped it heats up, causing a super high pressure area that blocks coolant from flowing passed that section. Check the interweb for the proper way to bleed your coolant, dont know if it is an SR or KA or what. Basically there is a 10mm (usually) bolt at the highest point of the engine that has water passing through it. You let the car warm up slightly then loosen the bolt SLOWLY letting the air/steam escape. When water starts coming out close it tight again. Repeat.
2) Leaking Coolant. If you are losing coolant its either boiling out of the puke tank or you have a leak somewhere. Its really easy to tell, look for coolant on the ground after idling/warming up.
3) Water pump not doing its job. If the water pump is bad or the belt is loose you may not be pumping enough water. Make sure the belt is tight and if possible just replace the pump, its 30 bux and about an hours work, worth doing anyways. Also, if you have a bad thermostat that is stuck closed no water will move through the engine and it will overheat, so check that too.
