Motor rebuild question on pistons
DRFT24O
Car: 1991 240SX Fastback
Im getting my motor rebuilt:new pistons, rings, main bearings, connecting bearings, all new gaskets, polished crank, bore block, hone block, (overbore) remanufactured cylinder head. How much more would lower compression pistons be then stock? If I wanted to turbo it later?
Ligouri Rd
Car: '96 Nissan 240SX
You can get pistons to give you 8.5:1 compression ratio. That (I believe) is equal to an SR20DET. Im running 9:1 pistons so that I have a bit more power before the boost hits and I don't plan on running a crazy amount of boost anyway. It may kinda suck to get your engine all rebuilt and have it less powerfull until your ready for boost.
WDRacing
If your getting forged slugs installed then you can get basically any compression you want and it should be close to the same price. I wouldn't go under 8.5/1 though. Just my opinion.
Florida240sx
I've noticed most turbo kits give you 8.8 or 9.1 compression pistons. If your going to have high boost wouldn't 8.5 be best? I'm asking..I don't know enough about this stuff to make valid claims.
XcreatureX
Car: 96 240sx SE
Yes, higher boost you would want to run lower compersion like 8.5:1, but like everyone said you would get less down low before hitting boost
Seth
DRFT24O
So your all saying that forged pistons are only slighly more expensive then stock? What else would i need besides pistons, and rings, and where should i buy?
DRIFTEADOR
vvaffle
Car: 1991 240sx base hatch, 2009 WRX
You can run plenty of boost with 8.8 or 9.0 compression. Definetly more than 20 psi and even more than that if everything else is done right.
nismo1003
Car: Ka24de
I heard the Audi A3 got 10.5:1 compression ratio running 15 psi . lol
how can they do that?is it becaseu of the DFI
blubottlemax
Car: Cars, aviation, snowboarding
The 3.0L Maxima has a 10.1 compression, and people have run 15psi or more through that motor with no work whatsoever. It all depends on how the parts come from the factory, and your fuel management.
