sli240sx »
https://forums.nicoclub.com/sli240sx-u3523.html
Tue Jan 27, 2009 5:27 am
hey everyone, just what to know what you guys think about my rebuild. I'm rebuilding my SR20DET S14 motor because I broke my head gasket. these are the parts I have so far.
Tomei Head gasket 87mm bore size and 1.2mm thicknessferria valve +1, valve springs, retainersCP Pistons 87mm with 8.5 compression with heat coatingBrian Crower proseries rodsDarton Pistion sleeves HKS step 2 264 camsTomei rocker arm stoppersARP head studs, main studsACL race main barings, rod barings
This car is still going to be a daily driver so I'm really not trying to make tones of power. Like to do some circuit racing track events. The turbo I'm using is a GT2871R .64 trim. I have Power FC already and Z32 MAF. 3" turbo back exhaust system. A question I would like to ask is would the HKS 264 cams too big? Will I loose too much power at the bottom? And another question is the head gasket. Is the 1.2mm thickness to thin should I have gotten 1.5 or 1.8? I would just like to maximize the turbo as best I can. I would like to make 400whp but as I see on some of the fourms that looks pretty hard to do. If anyone can give me some advice I would appreciate it.
