motor rebuild head gasket and compression ratio
scherger_16
Car: 1990 240sx SR20DET, 1993 Nissan D21 pickup
doing full motor build wondering what head gasket to use have a 86.5 bore t28 turbo probly run 20psi boost i head not to use cometic what head gaskets are good what are not. also the thickness how much is this gonna affect the compression ratio should i go to 9.o to 1 with a 1.1 mm gasket so i dont loose the compression ratio on a 8.5
Wretched
Car: 93' Hatch
stock oem headgasket ftw........ftw.
JustDriftMore
Car: 89+91 ku-pe
tomei ftw....ftw
kouki munster
Car: 97 base 240
Cosworth
/end thread
Edit: just use a stock thickness gasket and you won't have any problems.
boriquaS13
Car: 92 240sx
oem or cosworth
scherger_16
how about the greddy one are they good
visser003
Car: 1991 Nissan 240sx Coupe
scherger_16 wrote:doing full motor build wondering what head gasket to use have a 86.5 bore t28 turbo probly run 20psi boost i head not to use cometic what head gaskets are good what are not. also the thickness how much is this gonna affect the compression ratio should i go to 9.o to 1 with a 1.1 mm gasket so i dont loose the compression ratio on a 8.5
20psi on a t28 is past the efficiency area of the turbo. Have fun killing that heatpump quickly.
I wouldn't run it past 18psi (and not normally)
