motor question!
marshun
my friend has a 89 240. and someone down the street is selling his 95 KA motor.
what would be needed to make this work?
i was thinkin he'll need a 91-93 wire harness and ecu, some sensors here and there from 91-93.
but then again i dont know much about these cars yet.
any help appreciated :)
EazyBreazy
you should post this in the kae/kade forum youll get alot more response....
marshun
ohh ok.
im still pretty new.
anyone got any help to give?
node
nope you dont need any of that stuff assuming the 89 has the DE engine. Just swap the manifold over with the sensors and start that beast up. You may want to swap the cam too since the 95 cams arent as good.
jim
marshun
node wrote:nope you dont need any of that stuff assuming the 89 has the DE engine. Just swap the manifold over with the sensors and start that beast up. You may want to swap the cam too since the 95 cams arent as good.
jim
my friend's 240 has the single cam motor. does the manifold and stuff still just switch over?
obviously the cams wont switch over. so i wont even ask that question. hehe
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
the 89 is a single cam motor. your going to need the motor, the ECU and all engine sensors and wiring.
240marcuSX
Car: E34 525i
E46 M3
no, the manifolds dont just switch over.
node
yea they are correct you will need everything if its the SOHC
I will have all the stuff you need to do the swap in a couple of weeks if your interested I can send you an email when we finally pull the motor.
