Motor Problem
prigo
K, I got a KA24DE, and the other night on my way to the LA auto show, something happened, and the car started running like ***. So we towed it home, got it off the trailer, and it started running fine. I pulled it in my driveway and left it overnight.
Worked on it today, replaced the distributer rotor, cap, and spark plugs. Runs ok, but makes a ticking noise. We opened the oil cap, it got louder. Then we checked the timing, it seems to jump a little bit.
We're thinking its the timing chain, any thoughts before I take it in to the dealer and get "suprise sexed" ("rape" is not politically correct, so we say "suprise sex" now) over the work?
TurboKA37
did you ever have the useless upper timing chain tensoner removed? it could have broken off and maybe become cought in the chain for a bit? or one of the other tensioners could had broken if the chain is jumping around. you might have better luck posting in the technical section
prigo
^ Never considered that, its possible, but I don't want to eff with tearing the motor apart :(
Altiman94
Car: 1989 Nissan 240SX
if its ticking its likely to be lifters or rocker arms.
prigo
To me it sounds like the timing chain slapping, but i dont know for sure.
TurboKA37
did you notice if any of the tensioners/guides had fallen off or broken?
prigo
Couldn't see em through the oil cap =P
S14Life
Car: b5 s4 stage 3, 2001 pathfinder, 91 s10
Just remove the valve cover and take a flashlight and look. The valve cover is easy to take on/off.
prigo
K, will do :)
sideshow
Car: obsessed with cars.
altiman, there are no rockers on a ka24de, the single and dual have different valve trains
