Bump.... (motor is a KA24E)
So I checked the Vacuum lines. but I have some questions for those who know the EGR system very well.
1. The EGR Control Solenoid...at the top of it it has a line that comes from the intake manifold to it, and the bottom of the solenoid it has 2 lines 1 line has a T-connection, 1 goes to the BPT valve (and then to the EGR) the other line goes to the charcoal canister. The 2 line goes to some other solenoids in the back of the motor.
on the BPT the top has 2 lines (one comes from the solenoid the other goes to the EGR like I mentioned ^) then the bottom of the BPT valve it has one line that goes to the hard line that brings exhaust fumes back into the intake manifold.
(heres a diagram:
http://i2.photobucket.com/albu...m.jpg)
so my question is which line that hooks up to the BPT valve sucks to actuate the BPT valve in order to open the EGR valve? (the one from the solenoid or the one that brings fume back into manifold)
My EGR valve does work I hooked a vacuum tester and it opened. (then car was bogging)
Thanks and sorry for the long message
P.s. I also think this is a reason for my RPMs being at 1600, because the EGR isnt opening or something else could be going on with it.
