sweet that solves everything.neverlift wrote:yeah something is way off it sounds like....
hey florida you get that ecu yet?
Warming up past idle temp is normal. Also running the AC will increase the temperature of the air going through the radiator so your coolant temp is bound to rise.icnuthin wrote:anyway my temp is at 180 degrees and then i turn on my ac and 3min of driving it goes up to 200 degrees. i try to get all the air out but it seems that its not all the way coming out.
prob number 2 when it gets to 190 degrees. ok lets say i go to the store and and kill the car and about 2 min i get back in and try to start my car and it just turns (no start) if i wait 10 min it will start. starter works and engine is turning but it wont start.
and prob number 3 is my oil pressure reads right untill my water temp goes past 190 then it looks like my oil pressure drops.
ok im trying to burp out the air and its going slowly. pain in my rear.and since ive been burping it it hasn't done the not starting thing yet.but its so hot outside so it takes like 5 min to get up to 200 degrees. but its only when i drive. at idle it goes down to 176 after 5 min. and it will stay at 176 if i idle it all day.krazydriver wrote:
The car not starting when it's warm sounds almost like the ECU isn't properly configured for a warm start. I would start by checking that you have spark and can hear the injectors ticking when you try to start the engine warm. If not contact the ECU manufacturer.
Prob 3.Oil gets more viscous as it warms up. So as your engine temp increases oil pressure will drop. Cold start KA oil pressure is like 20~25 psi higher then once it warms up.
its actually a really good ecu. he is out of houston. i think the website is http://www.q-garage.comneverlift wrote:you do realize that idle and driving temps are gonna be tha same... if the engine is at a steady idle of say 700rpm thats a ton of explosions. When you driving rarely is the rpm that low= a LOT more explosions per minute = higher temps, that doesnt include the incresed explosion due to the throttle blade being open and letting in more air.... 200 isnt that bad IIRC nismo stat is 190. 176 idle is great.
as for the ecu, I havent heard of q garage.... sounds like a bad cts, but it really could be the "tuner" messed up/forgot a map.. Crazier shyt has happend. hope you get it sorted out
yea i did some searching and i think i got the wrong cts. i got the one for the 96 and i really need the one for a 91-94 but i just took it around for about 20 min and im running around 190-200. its really hot outside too.neverlift wrote:yeah I dont need the site but thanx...I rom tune myself and run an ota bov be its on blow through.cts is the coolant temp sensor, not teh one wire one(IT HAS TWO WIRES). chances are if its red/yellow its old,blue black purple are the newer ones IIRC, cant really ask you the vtec at 4grand or bad mileage questions though... check it with a multimeter.
That's an OLD SCHOOL way of reducing the the temp point on the thermostat. I did that on my F-Bird back in the day also.eazye2000 wrote:If you don't want to mess with air in the system, drill a 1/8" hole in the outside rim of your thermostat and point it at 12 o'clock.I personally drilled 6 of them in mine, and it worked fine.
I'm sure someone will find a problem with it, though.
