StarPD »
https://forums.nicoclub.com/starpd-u54244.html
Tue Feb 13, 2007 10:03 am
Okay, the consensus seems to be equally divided between 5w30 and 10w30. So I'm not much closer than when I started.
In view of the low mileage, I'm not sure that a hot oil pressure check at idle is necessary. I don't know what the dealer would charge me for doing such a test, but knowing their labor rate, I suspect that they would charge me for an hour or two, which wouldn't be cheap.
Doctrine has it that the thinner oils arrive at the valves and cams on cold start sooner then thicker oils, and that most engine wear occurs on cold starts. I understand that due to the different design of the cams and followers, this is more critical in the newer VK45 than in the older VH45. 5w30 then should arrive at the critical places sooner than 10w30, and the "30" part of the viscosity rating reflects a hot engine viscosity the same on both, meaning that in hot temps the engine is equally protected with both.
Considering that the newer VK45 engine consumes more oil than the older VH45, will the thinner 5w30 increase oil consumption over the 10w30?
If the "30" rating reflects the same effective viscosity in both oils, it seems that I'd be better served by using 5w30, even though Phoenix temps in winter are mild.
Of course, that presumes that oil consumption would be the same with both ratings, which is a concern.
So it look like, barring information that oil consumption with 5w30 will increase, that it's the way I should go.
More comments?
Thanks, guys. I appreciate it, and I suspect that others who might have the same questions but haven't stated them, will too. I think we are all still on a learning curve with the newer VK45 engine, and can use all the questions and answers we can get. This forum is the best source of good information, and of valid opinions of any that I participate in on the Internet. Most of the forums I contribute to arr about guns, but despite being an older guy, I love liter plus sport bikes too. Few of the forums I know of are as good as this one.
