motor not pulling! Please help!!
schanne
Car: 93 Hatch-Sr20
So I just replaced the TPS sensor to fix the no pulling problem. My tps was checked two weaks ago and was no good, we thaught that was the problem. after the third time we have the right one.. Took her for a spin, motor is strong, rebuilt stock parts but kometic head gasket. about 600 miles on it now. it bogs down when you heavy throttle but when its past 3000 rpms it seems better. One of my buddy's said its the clutch.. He says that cause his old 280z had the same problem and the clutch was bad. Could it be that???What does nico think? PLEASE HELP!!!!!!!!!!
Hijacker
Car: '92 240sx Convertible
'94 F-150
schanne wrote:So I just replaced the TPS sensor to fix the no pulling problem. My tps was checked two weaks ago and was no good, we thaught that was the problem. after the third time we have the right one.. Took her for a spin, motor is strong, rebuilt stock parts but kometic head gasket. about 600 miles on it now. it bogs down when you heavy throttle but when its past 3000 rpms it seems better. One of my buddy's said its the clutch.. He says that cause his old 280z had the same problem and the clutch was bad. Could it be that???What does nico think? PLEASE HELP!!!!!!!!!!
Check your timing. I've had bad timing cause my car to misfire and bog until 3000, and once the turbo spooled up, it would take off like a rocket.
schanne
Car: 93 Hatch-Sr20
timing has been reset to make shur, could it have skipped back?
What else could it be
schanne
Car: 93 Hatch-Sr20
BumpIt realy doesn't take off like a rocket at 3000 and more. it just feels like i'm pulling a damn tree behind me. i'll open throttle 100% and it goes nowhere!!!Could it be the clutch or wiring to ecu???
schanne
Car: 93 Hatch-Sr20
BUMP_ HELP!!
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
Any boost leaks?
skillzilla
boost leaks, bad mafs, any ecu codes?
schanne
Car: 93 Hatch-Sr20
how would i find out if i have any boost leaks? I'm going to check the ecu codes with my bud right now. and also I have the z32 mafs in right now. I'm going back to stock, but that'll be 2 days. You guys think that'll fix it???
redtop91
Depends on if there are boost leaks or thrown codes LOL. Did you get the ECU flashed for the Z32 maf?
schanne
Car: 93 Hatch-Sr20
no i didn't..
schanne
Car: 93 Hatch-Sr20
I cant find the thread that shows you how to reflash and what the codes are, do you know where the hell it is
redtop91
Ok well the Z32 maf can intake more air than your standard SOHC (AKA SR) MAF. If you didn't get the ECU reflashed for that maf you motor is taking in more air than the ECU is metering. That would be a problem. Not necessarily the source of your problem but definitely a probable cause...
schanne
Car: 93 Hatch-Sr20
do you know where a good write up on reflashing the ecu so i can do it now? if not thank you
skillzilla
Unless you have a ROM writer you can not just flash the ECU to accept the Z32 MAFS. Im surprised your car ran at all with it installed and nothing managing it. Did it start messing up rgiht around the time you installed the MAFS?
Anyways, heres a link to the ECU codes and how to check them:
http://www.240sxmotoring.com/ecufaultcodes.html
schanne
Car: 93 Hatch-Sr20
I have the Neo afc installed so it seemed like it ran fine.... i'm planning on going back to the stock maf in the next couple days... this moter was built and just added the z32 at begining.
skillzilla
Is the Neo set to recognize the Z MAFS? Either way, your car will run like poop with the Z MAFS and no correction. Try the stock MAFS and check the ECU codes.
kriskouki
Car: 240sx
cannot help
