Motor not getting gas
foreva_s13
Car: 240sx
i have a 91 240sx sei have a swap 95 motor and i jus cant get me motor to revive gas!!!i have try a lot of things but still everything i try jus doesnt work!please someone help me if u kno!thank
redsx13
Car: 93 240sx 03 350z
ware are u checking for gas? at the lines or in the motor? and was the car running B 4 u dropped the new motor in?
foreva_s13
Car: 240sx
the line and the motor and the fuel pump!!! no gas pumps at all!!!im gettin mad... im sure the car was running wen i bought it... it was sumbodys unfinish project and now im stuck askin for help!!!
redsx13
foreva_s13 wrote:the line and the motor and the fuel pump!!! no gas pumps at all!!!im gettin mad... im sure the car was running wen i bought it... it was sumbodys unfinish project and now im stuck askin for help!!!
so the car was running when u bought it?
with the ignition on, just check the leads to the fuel pump with a volt meter. connect the black wire of the voltmeter to a ground on the frame, and touch the red lead to each one of the wires going into the fuel pump. that will tell u if you are gitting power to the pump. ( if you dont have a volt meter, its worth the money to go out and buy one. Some are pretty cheap and its a good tool to have when doing a build)
let me know what you find
gumby74
foreva_s13 wrote:i have a 91 240sx sei have a swap 95 motor and i jus cant get me motor to revive gas!!!i have try a lot of things but still everything i try jus doesnt work!please someone help me if u kno!thanks
I am trying damn hard to just understand what your saying, let alone assess the problem. When you say you can't get the motor to revive gas, WTH does that mean?!? I normally get my motor an extra large bean and cheese burrito with extra guacomole when the gas needs some reviving. boy let me tell you...
Not trying to make fun brother, but more details please. What exactly is going on or not going on?What exactly have you tried that did not work?Make it easier for us to assist you, otherwise this will be just another senseless, random post.
leonelrr
Car: s13,s14, z32TT, YZF R6 None of them work nothing to brag about
What is this kindergarten?
foreva_s13
Car: 240sx
leonelrr wrote: What is this kindergarten?
ur funny
foreva_s13
Car: 240sx
wat i ment was the engine is not receiving any gas!!! my fault on that...
i check the line and the motor and the fuel pump!!! no gas pumps at all!!!im gettin mad... im sure the car was running wen i bought it... it was sumbodys unfinish project and now im stuck!!!
i did the test light on the fuel pump line connection and one of the positive lights up only a lil... the other lights up bright! well wat i did was test light it to see if ther was power and one of the positive on the fuel pump connection was kinda not brighting up... so i thinks dats the problem but i dont kno 4 sure.... let me kno how i can fix dat...
foreva_s13
Car: 240sx
i did the test light on the fuel pump line and one of the positive lights up only a lil... the other lights up bright! well wat i did was test light it to see if ther was power and one of the positive on the fuel pump connection was kinda not brighting up... so i thinks dats the problem but i dont kno 4 sure.... let me kno how i can fix dat...
