deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Tue Jan 18, 2005 7:30 pm
If the mount is not ripped or broken, scrub it off with some gasoline and a brush, then fill up all the ribs with some urethane windsheild install glue. You can also liberally build up the outside with the urethane, works really well and your mounts will be nice and stiff after a day or two dry time. The urethane is a bit messy, what i found to work very nicely is spraying some wd 40 on my finger to massage the finished product nice and smooth.
3M Windo Weld is the stuff to use, around 15 per tube at glass shop and will do 2+ mounts.
