Motor Mounts
Import Fanatix
Car: 1991 Nissan 240SX Fastback
I have a s13, How hard is it to change the motor mounts and transmission mounts and also how would i go about doing this?
Thanks
R240NA
It's easy. Jack up the car, and support it with stands. Place the jack under the motor/transmission, loosen the mounts form underneath, then lift it up about an inch, take the mounts out and replace them. Hour job max.
Import Fanatix
thanks i'll try it.
