SirSilvia wrote:I don't know if I'm reading you wrong or what but Nismo mounts aren't solid, they're basically just like stock but with a stiffer rubber in them.They're better, but I can get under the hood and press the throttle and see my engine torque left and right ever so slightly, maybe something like a 1/2" at most. Nothing like old azz ones that my engine moved almost an 1 1/2 back and forth. these right here are solid mounts and WILL transfer more vibrations through the body of the car.
http://www.bicperformance.com/...t.JPGTake a look at the Nismo mounts.see the two bolts? they do not line up because they are not one piece. there are two main metal pieces that the studs are welded/pressed into. and alternating rubber and metal till the other side. It's meant to flex a little.
http://www.frsport.com/product...3.jpg
if it's your entire car shaking and vibrating hard, then you have two things...1) girlfriend loves the ride 2) somthing in the engine is possibly out of balance, or something else making the engine shudder.
Glad you acknowledged you weren't sure on my comment unlike most of the other brain dead people who seem to post around here.
When I said solid, I was talking solid rubber, not metal or anthing.Nismo are rubber all the way though while the stock ones have grease inside of them.
When a car runs for hundreds of thousands of miles that grease starts to ooze out.
When that happens the engine mount is useless and your engine will flop around like a five dollar crack wh0re's vagina. That is where I believe the OP is getting problems from. But I'm pretty sure his problem goes deeper than engine mounts.
Skilz10179 wrote:I've been doing a lot of searching and reading on these Nismo mounts lately and there seems to be some confusion on how much they will raise the motor. Some people using them claim they don't rasie the motor at all and other claim their motor now sits about .75" higher with the Nismo mounts. It seems that there are multiple part #'s for the same mounts which may explain why some people had issues with a raised motor and some don't....
I've also read a lot of confusion about switching mounts, putting the left monut on the right side and the right mount on the left side. I've read some people say "it is a must" and i've heard others say they installed them without switching. I have also read that is you have a KA you must switch them but if you have a SR you don't. Searching on this site does a whole lot of good when most of the people posting don't have a clue...
As for the other post, the engine sits higher for two reasons.
It's stiffer than the OEM engine mount. So it will not compress at all when you drop the motor.
As well as like I keep saying, the old mounts start to wear out and the grease on the inside escapes the engine mount. When that happens the engine falls further down into the engine bay.
Once you install the nismo mounts (maybe even new oem mounts; cant remember) the bottom of the oil pan will be flush/higher than the sway bar.
But you will not run into clearance issues with your hood. So there is no need to worry about that.
The comment on running the mounts reversed? There is no need for that.
Left/Left, Right/Right.
