motor mounts install
Secret squirrel
Car: 1990 240sx w/ ca18det
so i removed my old KA mounts...big PITA. and im goin to put on my Nismo ca mounts...my question is, do i torque them and if so to what? i cant seem to find it in my fsm.
heres the old vs. nismo
http://img.photobucket.com/alb...5.jpg
thanks
-jeff
top_secret
you won't be able to get a torque wrench in there anyway just tighten em down good but not excessively. a dab of locktite might help if you are worried about em vibrating off.
Secret squirrel
yea...i knew id be hard to get the torque wrench down in there...so just tighten them down and us a dab of locktight eh?
SS
top_secret
I've never used a torque wrench or locktite and I've put motors in 4 times now and never had any problems...
Secret squirrel
alright thanks, anything special about the transmission mount?
and does anyone here have nismo mounts? after ive bought them im hearing it ruins daily drivablility from vibrations...
SS
top_secret
yeah thats been my experience with stiffer engine mounts.....
one of the big reasons I haven't installed them yet. Plus I really question the performance benefit, the power lost by the stock engine mounts has to be negligible, and the comfort sacrificed by them is considerable.I haven't ridden with the nismo ones though, so maybe they aren't as stiff.
Secret squirrel
damn...i hope my ride quality dont go to ****...this is gunna be my summer daily dirver...
SS
originalsin
i dont think you have to much to worry about, but a helpful hint, though u may alrdy know it, leave the motor mounts loose until you get the transmission x-member bolted back up
Secret squirrel
originalsin wrote:i dont think you have to much to worry about, but a helpful hint, though u may alrdy know it, leave the motor mounts loose until you get the transmission x-member bolted back up
motor is out because im in the middle of my swap...do i need to keep them a lil loose when in swap in the ca?
SS
originalsin
Secret squirrel wrote:motor is out because im in the middle of my swap...do i need to keep them a lil loose when in swap in the ca?
SS
yea that will help alot too to get them seated into the x-member
Kouks
Car: 1996 Nissan 240sx S14 Sr20det
I have them but havent installed them. They arent that bad actually, slightly stiffer than new OEM mounts.
Cusco METAL MM 's are stiff!
biosehnsucht
ride quality new nismo vs old blown mounts is better w/ nismo.
I like my cars stiff! just not knock filling loose stiff, and these aren't that.
I torqued. It's in the FSM someplace, forgot where exactly. EM section I'm thinking, I used like about 18" of extension to do it on the bottom.
put the mounts on before putting the engine in if you can, but not tightly, makes it easier to go in if you have them on but can wobble em about to line em up first.
tyrannix
Car: go big or go home
theres also something to be said about dampeners
i remember a gaigin car in japan had a dampener setup where it was really loose@ idle, so you wouldnt be shaking at stoplights, but either as you rev, or as boost increases, the dampener got stiffer
i forget if this was the same guy that filled his stock mounts with urethane... but thats also another option (if you have old CA mounts... most of mine got destroyed in the engine removal processes)
