Hawairish »
https://forums.nicoclub.com/hawairish-u243869.html
Thu Jul 02, 2015 3:00 pm
It's doable, but it won't be fun. You'll need to access the nut on top of the mounts from the engine bay, as well as the nuts on the subframe (which are located almost directly over the axle). And probably loosen some other stuff (transmission mount, hoses, etc) before either hoisting the engine 1-2" or lowering the subframe.
Can't say I've done it, but I've lowered my subframe and dropped the axle a couple times to get to the lower motor mount nuts to install my SFDs. I don't recall having enough room to do anything without removing the axle.
