Hawairish »
https://forums.nicoclub.com/hawairish-u243869.html
Fri Mar 12, 2021 4:55 pm
Changing the motor mounts doesn't require an engine hoist. The engine can be supported from above (engine support bar) or underneath (with transmission jack, among a few other options) while the subframe is lowered a couple inches. If you're 4WD, you'll also realize the front axle restricts access to bottom motor mount hardware, so it's best removed. This also helps with removal and installation of the mounts from underneath the truck; the engine mount brackets make it difficult to remove them from the engine bay, not to mention all the other junk up top that still blocks the way, even after clearing stuff out.
