DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Wed Aug 31, 2005 12:09 pm
oil in the cylinders, probably not so helpful.
a little more information would be helpful, is the motor seized up? Because rather than worrying about turning it over, you should probably worry about taking that pile of metal out.
Or are your valves hitting your pistons, because thats no fun either.
However, if you are really set on turning this motor over for some reason, you need one 27 mm socket i believe, one big breaker bar, and possibly one large pipe to put on the end of that bar for a little more leverage.
Spun bearings don't even make the motor impossible to turn over, i'm really curious to know what you did to yours
