Motor knocking a little sounds like a truck
MadmikeX3
Car: 1990 240sx SRBLKTOP With a potatoe
Hello i have a 1989 240 with the kaE and i kinda pushed the motor yester day just to see what it can do (not much) but once i slowed down and stoped for a second i could hear a pretty loud kncking sound from my motor so i parked it over night then today i started it back up and it still did it but i drove it any ways well after a lil bit of driving it went away but only comes back when im turning at slow speeds. I thought it may have been when i put throttle body and fuel injector cleaner in it it may have kncked somethig loose and was in the top og my head somewhere but i ruled it out but pulling out one plug wirte at a time and running the motor so i dont know what it is any suggestions?
goodstuff86
Car: Supras
when you rev it does it get faster? wut exactly does it sound like... hopefully not a rod knock or bearing good luck
MadmikeX3
well its like i guess a woodpecker on metal and when i rev it gets faster but it had stoped but only hear it a lil when im yurning slow and im barely on the gas in second ya know?
MadmikeX3
let me know if you have any soulutions anyone
sleepyRPS13
Car: to sleep
loose bolt exhaust manifold?
180fan
Car: 89 fastback
I've got my money on a busted slack side chain guide.
MadmikeX3
actually yes there are a couple bolts not there on the header but i see no sign of leaks or anything.
sleepyRPS13
Car: to sleep
that means you exhaust is rattling, try fixing it see if the noise goes away.
fullthrtl_tech
Car: 93 240sx
180fan wrote:I've got my money on a busted slack side chain guide.
MadmikeX3
ok ill check both and ley you know what ive found
Arrow
Car: 1990 240SX SE - SOLD
2003 Kawasaki Ninja 250R - SOLD
2009 Kawasaki Ninja 650R - corner carver
1998 Pathfinder
also another thing that you could look at would be oil... b/c my '90 will knock occasionally... and from my understanding it is the hydralic lifters knocking or rattling when the oil level / pressure is low... so on cold days or whenever my oil level gets low (it leaks a little) I'll hear a rattle... add a little oil and it goes away... Just an idea though...
MadmikeX3
OK thankx i will try all of this onece i get mine back from the wiring shop
Zion8561
Car: 92 Nissan S13 Fastback
MadmikeX3 wrote:well its like i guess a woodpecker on metal...
Thanks, I neded that
Seriously though, it may be low oil level if it is only in turns like arrow mentioned ^^^.
NorCalDrift
Car: 1990 Nissan 240SX SR20DET
At around 2300 RPM's is it consistent? If so rod bearings is my guess.
kona240
Car: 89 hatch, 92 vert
mine ticks like that when im low on oil or when i pound on my car. just add a little of oil.
SwiftS14
Car: S14
my car also makes that ticking sound, but thats after i hydro-locked it. runs find, did a compression check, all was even accpect the last cycl #4(145psi)
