absolum »
https://forums.nicoclub.com/absolum-u48613.html
Tue Jul 24, 2007 3:22 am
Hello guys I am really out of ideas and need your help.I am running a T3/T4 set up on a sr20det. I am currently running about 7 psi of boost, I have a wideband and monitor my air fuel whenever I hit boost.There is a strange issue that happened, My car is destroying my spark plugs.Doing some mild boost , The motor started to knock violently almost as if there was something loose in the motor itself. Description would be like having marbles inside a cylinder. The motor was also running on 3 cylinder. I pulled the park plugs and the spark plug #4 had the side electrode pressed in the center electrode ( yes you read right ) , there was no gap on that park plug, it almost looked like someone hit it with a hammer , Yes there were touching. These were bkr7.The safc knock was showing 35 recorded count of know, I though it knocked while in boost and detonation destroyed the plug so I bought a new set of spark plugs and upgraded to a 8 heat rating spark plugs. I even used a magnet and try to sweep the cylinder just in case. Nothing. The knocking diseapeared as soon as I changed the plugs , got home done a compression test and getting about 160 across consistent . Just for safe measure, I up the air fuel from 11.5 to 11.0 . I drove the car for 1 week in and out of boost and it happened again.This time while boosting heading home. Important * this time I was checking for knock while boosting and the knock started to register as I started running on 3 cylinder, The # 4 spark plug again had no gap , the electrode were pressed against each other.I pulled the valve cover and cranked the motor manually and the valve, retainers and rockers are all moving the way they should.Put everything back in and started the car, mad knock like you wouldn’t believe.I get in the car all pissed off and give it a good rev to about 5000 RPM , Noise is now gone and car is running 100% ok.
I am really scare of boosting this car now. What could be the problem?
What are the odds of it been the piston hitting the top of the spark plug while in boost? Could it be a stuck valve? What can do this to a spark plug. Notice that the destroyed spark plug is only originating from # 4.Are my rod bearings loose?
HELP , I am seriously running out of ideas
