Phax wrote:What kind of clutches are you guys using? I know for a fact that if you hammer on a kevlar clutch by giving it full boost, you're going to glaze it.
My take (based on the link I posted above):-you should be running as little boost as possible (an engine I just helped a friend break-in was in a car running a standalone ECU and speed density metering, so we ran it in n/a mode for break-in)-unless you're on a dyno, going WOT isn't necessary. i've always just gone half throttle or so up a hill to create a bit more load on the engine
If you aren't using a new clutch, none of this is an issue
the main point is don't baby a new engine. An engine has to have load put on it and has to make the transition from high-vacuum (idle or coasting) to boost (or near-boost, as in WOT on a n/a car) in order to properly seat the rings.
~matt
