motor hesitates/bogs under all conditinos
undead310
Here are the facts-
-Motor turn and idles fine until gas petal is pressed on.-Once gas petal is pressed car begins to move but jumps (stalls and goes) constantly and dies if gas is not smashed on and held over 3k to 3.5k rpms But Eventually dies anyway with in a few minutes if it isnt in constant motion above 3k rpms.-In order for me to move the car I have to keep it up on the rpms and shift =(- Engine has been sea foamed and checked for leaks and none can be found.
-There is also the ticking coming from the back of the drivers side fuse box,which is hell trying to pinpoint where its from.
Thats the issue, the search function has been used but I was curious if anyone has had the "exact" same issue with a KA24DE motor. Thanks in advance
Modified by undead310 at 9:09 PM 8/20/2009
GO240
Car: 1990/1/2/3/4/5/7 240sx lol
can you smell raw fuel? and you may want to have someone pull your fuse box and make sure it isn't all jacked up mine was but the whole car wouldn't start
undead310
GO240 wrote:can you smell raw fuel? and you may want to have someone pull your fuse box and make sure it isn't all jacked up mine was but the whole car wouldn't start
Naw negative on the fuel smell, as far as he fuse box everything looks fine behind there. This problem only started a few weeks ago and hasnt went away. I have tried looking for a possible solution etc. etc. during this time and about to start asking if anyone knows a reliable mechanic who works on nissans primarliy. =/
Ajizzy
Car: s13
Maf sensor
GO240
like he said check the maf then if you must take it to a mechanic that knows his stuff that you know
undead310
Ajizzy wrote:Maf sensor
awesome ty will check it out this weekend and let you all know, I will also invest in a code reader from the local kragen and see what codes pop out. Much love and ty in advance ^_^
