RED_DET »
https://forums.nicoclub.com/red-det-u7295.html
Sun Mar 02, 2008 8:58 pm
An injector may have stopped working. Its known to happen. With the engine idling, undue each injector harness one at a time and plug it back in before you pull the next one. If th cylinder that is misfiring doesn't respond when you undue the harness, that is probably the faulty injector.
