Motor done twice still stuffed
djturbo
Car: Music and cars
:help Motor stuffed .Need Technical specifications ons13 93 240sx limited edition coupePlease HelpDesperate[email protected] Please anyone that can help.no one knows these motors in South Africa.It is importedNeed technical specs not normal specsHow do i fix my stuffed motor
MikeS14240sx
Car: 98 Nissan 240SX
What do you mean by the motor being stuffed? I have never heard that term before.
djturbo
Car: Music and cars
The head gasket keeps on blowingthe manafold also keeps on blowingand ive got no compression what so eva and im in South Africa and no nissan engineer has ever worked on a car like this before so i need the technical info of the motor so he can try and fix it properly this time and also order the right parts cause it is costing me so much money
lessthanjakejohn
Do you have a CA18det or a SR20det?
djturbo
Car: Music and cars
dont know what you are talking abouti just bought the car
djturbo
Car: Music and cars
can you help me
Aries
Car: LT1 240SS
if you can describe your motor, or post a picture of it, then we can help.Without knowing what motor is in the car though, it is quite difficult.
lessthanjakejohn
Open up the hood and look at the valve cover
MikeS14240sx
djturbo look on the cars identification number plate. Its on the firewall under the hood. This well have the engine series on it. It will probable start with CA or SR.
djturbo
Car: Music and cars
:help here is a pic of the motor i need technical specs of the motor desperatly please i need to fix my baby.Its an 1993 nissan 240 sx se limited edition cabriolet(coupe)Engine model: KA24DE
lucas_420
Car: 92 240 hatch
this says detonation to me, but Im not sure.... exactly what specifications are you looking for? are we talking timing specs or things like flow rates and volumetric efficiency?
also...with a KA24DE it sounds like you have a USA spec car can you get ahold of a Chiltons Manual? That should help a lot.
you can get them here
what exactly do you mean by this...
Aries
Car: LT1 240SS
Use a copper gasket on the exhaust manifold.
the headgasket is blowing due to one of a few things.1. crank walk2. horrible timing causing detonation3. wrong gasoline causing detonation4. low fuel pressure causing detonation
