motor doesnt want to crank...
jdm_lover
Car: 91 240
91 240sx its been 2 months now and ive tried the new starter to new batter and new battery post, new clutch switch....
the car just doesnt want to start...when i turn the key to start the car...you just hear a click by the relay box by the intake. i think its the acc relay...but then could it be that...or wire short or the ignition switch....doesnt want to seem to just budge....i need help....
5upra
Car: S197
check starter wiring!
teddy
Car: Saab Turbo and MR2
if its not cranking, then the starter isnt getting any power. I agree, check all your wiring.
Ni2s4s0aSnX
Car: Nissan 240sx 2.4L 12Valve
You did ground everything correctly, right?
jdm_lover
Car: 91 240
jdm_lover wrote:91 240sx its been 2 months now and ive tried the new starter to new batter and new battery post, new clutch switch....
ok...i decided to connect one of the wires thats black/yellow from under the steering wheel. seeing its one of the wires from the ignition switch i decided to reconnect it. i dont knoe if u can connect it or not. but the car was runnin fine before with this wire cut before...
so on, so i decided to connect it and now it cranks ...its just that it wont start...it keeps cranking...i hear the fuel pump working and the distributer seems to be working cause i tested it with a sparkplug wire tester...and im out of idea's
theres a thread on here that seems to be a little issue to be like my issue so ill post it right here....zerothread?id=157044
any other suggestion?
