Florida240sx wrote:Had my engine tore apart today. From driving 5miles with 2 injectors leaking it caused 3 bearings to be shot.#1 cylinder was the one knocking. Luckily crankshaft is fine. On the head one of the cam journals started to wear but not severe. Was only on my exhaust cam that this started.Current rebuild: Crower v2 cams CP piston 9.0cpr Cosmetic HG Clevite bearing Everything else stock
Going to boost 15psi daily and then add some lbs here and there Car is weekend driver mostly.......
Bah, go for the gold! Get some crower connecting rods in there man...15 psi on stock rods that are high mile is a lot of stress to handle...and oh so little block to rod clearance...(my fully built engine blew at 16 psi from a small t3)
If you dont have enough money for both the crower rods and cams, then ditch the cams....the cams have nothing to do with the longevity of the motor like connecting rods do...Not to mention, if you get cams, you'll want to get larger intake/exhaust valves, and at least a 3 angle valve job if you want to completely maximize the higher lift/longer duration than the stock units. And after you do all that, may as well change out the valve springs and retainers too...
It adds up...rods should take precedence over cams.
