trpower7 »
https://forums.nicoclub.com/trpower7-u205.html
Mon Nov 24, 2003 6:26 pm
A LOT of misinformation here. First, SOHC and DOHC pistons are VASTLY different, if you put SOHC pistons in a DOHC you'll get a very turbo-unfriendly 11.0/1 compression ratio (I may be off by .5, but it's still high), and vice versa with DOHC pistons into an SOHC. Rods really are quite unecessary as they come forged from the factory and the cases of KA's bending the stock rods are extraordinarily few and far between. Arias pistons are a great choice, I also like Wiseco and JE. Spirolox rings have also been proven very reliable on a KA. $800 sounds very high for a port/polish and valve job, every one I've done has run right around $450-$500, maybe a head rebuild with new valve guides, etc, for $800.......If you don't have much money to spend ditch the head-work and rods and get some REALLY FREAKIN GOOD FUEL MANAGEMENT. It's going to get you a LOT further than anything else. Good fuel is the key.........
