I think if you add it all up, they kind of overpriced it.
http://www.undergroundmotorsports.com/
eagle rods$320 It's included w/ arp bolts(p2m)Pistons around $500, i bought my Arias 8.8:1 $450 (ivan uses arias in his 9sec ka-t)ARP main$105, ARP head stud $110(p2m)Cometic HG $86(p2m)Clevite main/rod bearing $75(ams)Mr. Gasket exhaust manifold gasket$30(autozone special order)
$1226(this is if you pay cash then usually they dont tax, or if your out of state) Plus you can also ask for a better deal if you buying from one place, they always down to do it.
usually oil pump dont need to be replaced, just make sure to inspect it. OSK timing chain kit is $150(frsport.com) and works good.
If your not planning to run over 400whp then i think you should just get complete Felpro gasket set comes w/ HG also and can support up to 500whp. if you're not planning to resurface your block and head then cometic can be bad and it might leak on you. so best is felpro. too many people had bad experience w/ cometic.
Hope this helps..
GL
