S14 SR breaks up under load
Former_240_s14
Car: 07 BMW 335i Coupe
Hey guys quick question:
Intermitently my motor begins to break up and stumble under acceleration. It idles perfect and when its not under load its fine. I have checked all the hoses and clamps that would be vacumed related and they all seem fine. I also doubled check my exhaust to make sure its all buttoned down as well.
I am thinking its maybe that my fuel pump is begining to bite the dust.......
Any thoughts?
Thanks,
Rubin
snake240
Car: 92 hatch SR20DET
if your running the stock pump then id say thats the culprit. i would def upgrade and get a an adjustable fpr as well. im running the nismo and just got an inline gauge from summit.
Former_240_s14
I am not running the stock pump. I was told it had a walboro unit when I bought the car but its been in there for a while. I have checked the following other items and cleared them of the issue:
Coils
Boost Controller
Visible Vacum Lines
Exhaust leaks
It's making me wonder if the pump is just dying.... Its very very intermitent (sp?). The car runs like a scalded dog for a week then runs rought for another.
Thanks for the input
Rubin
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
i had that same issue and it was a slowly failing fuel pump (walbro) It was friggin terrible to diagnose because it idled very well but would seem to pause going through 5-7800 rpm. Strange occurance but i check and cleaned every damn thing u could think of. Tps, maf, throttle body, fuel pressure reg, fuel lines, fuel filter, spark plugs, coil packs.
Blown240sx
Car: 1996 240sx
Id also check your spark plug gap. You could be blowing out spark.
Former_240_s14
Thanks for the input. Since my last post I have done the following....
replaced fuel filter
replaced plugs
Still same issue. My buddy who works for a performance shop is going to check it out friday. He did the install and thinks it could be the maf.....I still think there is a small issue of a failing pump but he is definately the expert.
Keep your fingers crossed.
Rubin
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
Bad MAF should cause the same issue whether the car is under load or not..
