WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Wed Nov 19, 2003 5:21 pm
Pull the valve covers, the head probably has a ton of old oil caked around the cams and bearing caps. Inspect the timing belt and tensioners. Check all the coil packs, make sure the electrode inside the rubber boot is still attached to the spring and that it isn't completely worn. Check the compression to, if you have a kit. Most of the motors over look just like that, the damn salt is horrible in the air. So it makes the motor look alot worse then it really is. Best of luck and happy boosting.
WD
