elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Sat Nov 19, 2005 4:24 pm
Well SOMEONE is being lazy and isnt searching enough!!! just because you have a NICO members Q doesnt mean youll get special treatment!!!
Anywho.... If your specifically talking about upper links and you just want to replace those, id only replace with OEM or with a midori style upper arm from SPL or something similar....
When talking Z32, there are 2 types of arms... The OEM type (includes stillen) and the midori type. there may be more, but i dont care about those.... The OEM is a simple dogbone style... The OEM is not adjustable. The stillen ones use poly bushings that can be greased and replaced. HOwever, they cannot be as finely tuned as the midori style can. They have like 4-5-6 "notches" that you can chose from and thats what your stuck with. The midori can be fine tuned perfectly.. They are opposite threaded on each side... So basically you loosen these collars to lock in the alignment, and then twist them... that will push each end of the link farther away or bring them closer together... it is very probable that with high miles that the drivers side may need less camber correction to get to OEM spec than the passenger side... You can get a perfect alignment with these puppies, thats what makes them choice. They may be slightly harsher, but i dont notice much difference... They use bearings instead of bushings.. If you go with the midori style, YOU MUST USE A SOLID ADJUSTABLE TENSION ROD otherwise the bearings will wear out.
Again, i never recommend anything that I wouldnt/havent do/done..... so if you dont want to give up ride smoothness, go with OEM.. IF you want the best but will sacrifice some smoothness, then go with what I said..
To give you a short answer, all the Z32 links will change over.... That being all the rear suspension links (so long as their adjustable), the front links (uppers, lowers, tension rods, etc) will go over... The shocks and springs are different.....
Now use that little red button next time!!!
