Most power out of KA24DE?
Vader1_240SX
I recenlty purchased a 93 240.......How would i get the most power out of the KA24DE engine witout swappin it with a SR20DET, anybody help me out with a list of mods , start wit basics , then advanced. Im new into the motor thing, so any help will be appreciated. Oh also its an automatic.....if your wonderin why i got an automatic its cause i got it for only 1800 bucks :ylsuper Thanx a lot.
Vader1_240SX
Oh , one more thing, or would it be easier just to swap it out wit the SR20 just so i can get the better upgrades?
reds14
Car: working on my car
If you are wanting cheap,decent horsepower I would put intake and exhaust first,then maybe plug wires,header,etc. But if you are wanting to get alot of horsepower then I would go with the sr20 because it has alot more potential and aftermarket support. But it costs more.
RedHatchback
Car: was a 240, now a cobra, soon a z32 TT
It all really depends on which way you want to go.You can build the KA all motor,but you won't get much hp without internals and even then you still won't get much higher than 200hp and you'd spend alot do'n it. You could also Turbocharge the KA.Run a good 5-7 pounds on stock internals w/o blown it and you could get anywhere from 190-275 hp.And finally,the easy way out,SR or CA swap,both will cost a pretty penny,but in the end 205-700hp beasts,well worth it.As I said,it all depends on what you want and what range of horsepower you're shoot'n for.
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
You could have a 185rwhp KA24DE in your car, and if it's still attached ot that automatic transmission, you'll still run slower than a stock-ish 5-speed.
If you want to go fast, you need a 5-speed in that car....then add power.
- Brian
twofourzeroSX
Car: 91 sileighty
i got my 93 stick for a grand....unfortunatly it has 212k on it..but still a steal
RedHatchback
Quote »You could have a 185rwhp KA24DE in your car, and if it's still attached ot that automatic transmission, you'll still run slower than a stock-ish 5-speed.[/quote] Thats not neccessariily true. My auto w/ I/H/E/ kept up neck and neck with a 5spd w/ I/E/. He only got me by 1/2 a car length
:: orion ::
One race does not make it an absolute.
My auto S14 ran a best of 16.6 @ 84...that's relatively quick for an auto. Similar mods to yours...
Same car, less than a month later, at the same track...but now with a 5-speed: 15.6 @ 89.
Not to say an auto with more power can't be a fun car...it'll just never be that fast...as the 240SX doesn't have a great power-to-weight ratio anyway, and then you cripple it with an auto.
I'm only pointing out that $800 spent to make the car faster will still have him in the 16s, whereas $800 spent on converting to a 5-speed will have him close to a second faster.
- Brian
un_known
Car: 1990 Nissan 240SX
SR's are cool and all but i still stick by the words of some random guy, "no replacement for displacement". You can build a ka up more then 2. And trust me, there is plenty of support for the KA. Also, unless your handi-cap in some way, a manual gear box would be a much better choice.
ZeroS13
I'd be happy with 180rwhp for AutoX duties. ;)
barrigas14
a guy with a KA in Az has laid down 530+rwhp. the bottom end is rebuilt but the fuel management and other things like that were stock until JWT tried some prototype stuff on it.
:: orion ::
barrigas14 wrote:...but the fuel management and other things like that were stock until JWT tried some prototype stuff on it.
Whoa, whoa, whoa...
That fuel system is nowhere near stock. Don't confuse the newbs...
He was running a JWT ECU with 72lb top feed injectors, billet fuel rail, Cobra MAF, big fuel pump, etc...
Now he's trying a Ford Lightning MAF (4" ID) and 96lb/hr injectors...shooting for +600rwhp.
- Brian
slc240sxse
Car: 96' 240sx SE
Your best bet is to hit this site:
http://ka24development.com/
Get there, and read read read.
barrigas14
:: orion :: wrote:Whoa, whoa, whoa...
- Brian
ok ok i messed. i should have said easier to do...or something along that line i guess. but imo the og setup he had was truly easy to do and with the power he put down more than enough. at least it wasn't some kinda of $2k stand alone...that is what i should have said. it was not a $2k stand alone. anyways that new JWT thing is going to be freaking crazy.
98s14inaz
Car: 2010 Nissan Titan Quad Cab
- Brian
Actually that last run was with the JWT prototype program for 96lb injectors and the Ford lightning maf. Mike Lee is a KA-T god :ylsuper
You have a few websites you can go to... http://www.ka-t.org and many others.
