Most Performance Gain For the Lowest Price
Shift_4life
Car: 1988 RX-7 GTU
none
celica3sgte94
Car: 99 g20 89 240sx hb with 95ka24de
hahahahhahahha i love this ahhahah
Shift_Kouki
Car: 95 Nissan 240SX SE
List of silly things that are free and give almost no gain:
ignition timing advanceopen headersim sure the list is longer in the end....
Brandon93240
Car: 1993 240sx
drink some everclear and then piss in your gas tank, should gain atleast 3 drunk power.
krazy88
Car: 1989 240sx
Depends what 'cheap' is. Of course all of the breather upgrades would help. And thats a good place to start. Can be really cheap if you can fabricate the parts yourself.
Shift_Kouki
Dont know about "cheap".... But some lower dollar things cant hurt...
Altima cams are what $40 a set from a junk yard? Thats pretty cheap for a slightly better cam. (if you install yourself)
Timing advance of an extra 5 degrees BTDC... free in parts, and free if you do it yourself.
If you have a DE motor, SOHC pistons can up compression. But we are quickly moving past the range of 'cheap'.
Full exhaust is relatively cheap, but gains are nothing amazing. Same thing w/ intake, although thats a bit cheaper.
Beyond that, start thinking about removing rotational mass from the drive line. Flywheel, drive shaft, under drive pulleys, electric over clutch fans... etc.
But really the cheapest way to make HP would be the old NOS trick, but in all seriousness... NOS is for pushrods.
Shift_4life
Car: 1988 RX-7 GTU
I bought an AEM SRI and its about a 5hp difference. I cant really feel it but it sounds better. Im thinking about installing headers myself. How long does the average install take? are HotShot headers a good brand?
Bigvinnie
Car: 2004 Nissan Frontier desert Runner, 2014 Nissan Titan
Shift_4life wrote:I bought an AEM SRI and its about a 5hp difference. I cant really feel it but it sounds better. Im thinking about installing headers myself. How long does the average install take? are HotShot headers a good brand?
Hot shot is out of business. Yor best bet i sthe DC sports header which will add 9HP to the wheels.I would honestly go with a header or electric fan set up.
Or if you want to properlly advance the crap out of your timing (past 30BTDC) on your KA you could get an SAFC and a wideband to readjust A/R ratio as the timing is advanced (thats the only way to make some real HP with advanced timing on these engines.)
