most hp
lowblocks
Car: 1995 maxima
what is the most hp could you get out your car with all the mod without the force induction can you all make a listb pipe+cat=5y pipe=15wai=5vi=20udp=5so that's 50hp give or take a little but i know there is more please list them
maxhopper
Car: 02 Maxima SE 6spd
Well you could install JWT cams, or make a stroker motor from the bottom end of a 3.5 with the top of a 3.0. I don't have any hp numbers off the top of my head for them. You could have the heads worked, or bore the cylinders...the possibilities are pretty endless.
PBfrEAk
Car: '00 Frontier (Newb) '92 Maxima (Daily), '93 Max (Donor), '91 Max (Project) '77 F-150 (Funmobile)
This is going to be a very dumb question on my part but...what do you mean by stroker motor?
lol
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Increase displacement by increasing piston stroke.The 3.5 has longer stroke (and bore) than the 3.0, so you can use the crank and rods from it with the 3.0 and end up with something like 3.3 liters.
93HATCH240
Car: 1993 NISSAN 240SX HATCH
lowblocks wrote:what is the most hp could you get out your car with all the mod without the force induction can you all make a listb pipe+cat=5y pipe=15wai=5vi=20udp=5so that's 50hp give or take a little but i know there is more please list them
You just cant add all of them up and say Ill get 50hp from that. If it were that easy everyone would be doing it. with all that done you might get 15whp. you can doIntake,header exhaustcluch/flywheel if manualvalve body upgrade if your autoecu raised rev limiterhead work with high conmpressino internals.The list goes on and on. What type of power are you looking for and whats the power being used for. Drag? autoX? depending on what you want you will need to do diff. things. Along with doing brakes so you can stop as fast as you can accerlate. suspension.
Beancooker
Car: Current Car: 2024 Tesla Model 3
Past cars: Way too many to list
If you're staying away from forced induction, and don't want to spend too much under the hood, you can keep all the internals stock, leave the fuel pump stock, and add a 50hp shot of nitrous oxide. That will be a simple way to give you an extra 50 hp and it'll cost you about $1000 for the best set up around. You will have to change out your spark plugs and run them a step colder. You can change out the fuel pump and go two steps colder on the plugs, and run a 75-100hp shot.
Here's a nitrous article that I wrote a while back. It should answer a lot oif questions that you may have.
Oh, and done correctly, nitrous is very safe for the engine. The key is doing it correctly.
