NJGuy »
https://forums.nicoclub.com/njguy-u191160.html
Mon Aug 21, 2017 7:30 am
Sorry if I can't answer your question directly.
The 3.5 and 3.7 motors, and the 5 and 7 speeds were used in quite a number of models, including:
G sedan/coupe/Q40
FX/QX70
M/Q70
350Z/370Z
I believe the transmissions have also been used in Nissan's truck and SUV line as well.
I haven't looked extensively how the engines and transmissions have held up over time across all the different models, but at the same time I haven't seen anything alarming about them either that would make me question their reliability. As far as the EX35, there have been a few threads that have popped up about engine issues. At least for the earlier models, the most common issues I've seen had occured on the throttle bodies and the timing cover gasket.
For the transmissions, the only big issue I've seen was actually due to radiator failure. What would happen was that the lines between the coolant and ATF would corrode through and mix the fluids. This resulted in a "pink milkshake" in the transmission, necessitating a rebuild or replacement. This was much more common in the Pathfinder, Frontier, and Xterra models built prior to 2010, but I don't recall seeing this happen on their Infiniti models which likely use different radiators.
I know that the transmissions are defninitely rebuildable, and that the engines should be as well. However, unless a major failure occurs early enough in the vehicle's life, personally I think I would skip the rebuild and upgrade to a newer car. Rebuilds tend to be quite expensive with the amount of labor involved, and for me it would probably make more sense to put those costs into a newer vehicle. My situation warrants reliable transportation, and while I wouldn't have to worry about a newly rebuilt major powertrain system, the rest of the car still is still older and carrries the wear and tear along with it. I'm not sure what your situation dictates, but getting an engine/tranmission rebuilt may be a more sensible solution for you.
My EX35 now has 137K. It has had it's share of issues, but I think 200K is acheivable without requiring an engine/transmission rebuild. I'm not sure how well other components will fare however by that time. Even if I reach that mileage without any issues, I'll probably look to upgrade to something newer around that time and keep the older car around for a while. 250K is probably achievable as well, but I would guess that the likelihood of problems only goes up as the car passes that milestone and it would really push my risk tolerance for a daily driven car.
