Most Common Repairs?
Mr.J30
What are some of the most common repairs that need to be done to a 94 J30 other than regular maintenance?
driverdriver
Car: NICO's longtime resident Canuck!!!
That's kind of a loaded question.
It really depends on the previous maintenance of the vehicle and the age and also the location where the vehicle has spent most of its life.
I would only, but a J today that has got full service history. These vehicles are expensive to repair. A lot of parts are Nissan OEM only.
Victor
Car: 1994 Infiniti J30T
This is based on my experience only.1. Flaky drivers power door locks2. Headlight relay3. parking brake pedal not releasing fully4. Dashboard dimmer control
brandonjustice93J30
Car: 1993 Infiniti J30
Victor wrote:This is based on my experience only.1. Flaky drivers power door locks2. Headlight relay3. parking brake pedal not releasing fully4. Dashboard dimmer control
I agree with all of those...phantom door locks have been an issue for years, seems to come and go away. Same with the rest really, smack my dimmer and it comes back on, pull up the parking brake with my foot occasionally, and had to replace the relay once both headlights started going out. Ol girl was getting scared of my driving in her old age and kept closing her eyes...lol
other issues I've had were the thermostat housing leaking, passenger side window would go down on it's own in the rain, transmission would shift erratically in the rain after I got it flushed, I think the shop didnt get a seal in a connection back seated properly, the rear panels under the back doors are rusting thanks to Indiana road salt, one I havent experienced but heard of is the sunroofs tend to leak if you dont keep the drains cleaned out, which can leak into the engine computer and short it out, I'm sure there's other issues, but if it wasnt for a growing family, I'd keep the J well over 300k and restore it. I love the car and would buy another if they still made it. But the day of it's retirement may be soon.
SilverJ30t93
Car: 1993 Infiniti J30t
I think I figured out Infiniti's J30 door lock conspiracy. Look at what they termed "selective logic" automatic door locks on the window sticker. Perhaps their engineers intended for them to work illogically at times!
brandonjustice93J30
never thought about it that way before...lol..good point
gr8scott72
Car: 1994 Infiniti J30t
Leaking exhaust manifolds.Worn out control arm bushings.Worn out struts that you can only get at Infiniti.Costly timing belt replacement.Broken or cracked headlights.Worn out leather on driver's door panel.BOSE radio craps out.Alternator will die sooner or later.Knock sensors go bad.Door locks malfunction.Headlight relay.Dashlight dimer switch.Fuel injectors fail.Sunroof motors quit.Window regulator/motors die.
Mr.J30
ANYTHING ELSE I SHOULD KNOW BEFORE I BUY THIS J. IT HAS 185K ON THE BODY AND ENEGINE. 70K ON THE transmission AND I DON'T KNOW IF THE TIMIMG BELT, WATER PUMP, STRUTS/SHOCKS OR UPPER ARMS HAVE BEEN REPLACED. IS THERE ANYTHING ELSE I NEED TO KNOW OH IFINITI GREAT ONES
driverdriver
Can you please take your caps off? Its sounds like your yelling.
Don't take a chance with your timing belt, if you know it hasn't been done (or supect it hasn't been done), get it looked after first. The J30 engine has an interference design, when the belt goes your engine will be toast. You'll be looking at big bills for either a rebuild or a new one.
Mr.J30
Sorry about the caps.....
gr8scott72
So, how much $$$?
