Aegis156 wrote:As you can see I need to redo the headliner and replace the cargo area carpet. I also need a passengers rocker panel, I found 84-85 and 87-89 on the web last night but none for an 86.
86's are unique and you will need to find them from another '86 model.
Aegis156 wrote: I ran the Vin through the Z registry to find the interior code and it came back as black on black, thought the interior is obviously blue. So I still need to find the code for the original interior color.
You found it. But if you want a second opinion, the color codes are stamped on the model plate that's under the hood on the left strut mount.
Aegis156 wrote:Because I'm like instant gratification I dropped in a battery, 5 gallons of fuel and a bottle of Lucas injector cleaner, the engine runs clean at 1200 RPM, no miss fires or rough idle at all. I had 2 issues the AC compressor is seized (not surprising) and something has died in the duct work. I kept an eye on the underside to see it leaked anywhere, after 30 minutes not a drop. oil pressure stayed steady at 30#, temp rock steady in the middle of the gauge, 14 volts off the alternator (disconnected the battery for a bit to see if I needed to alternator)
You should never do that on a car with an ECU. You run the risk of frying the computer. That old school tech may have worked on cars with carbs, but you can fry electronics doing it on a modern vehicle.
Aegis156 wrote:I'm really leaning towards keeping the car stock, or at least only doing minor mods to it, nothing that can't be reversed in 30 minutes of wrench time. Since I will either be giving it to my kids to drive or selling it outright I don't want to dump a ton of money into the car. All in all I'm extremely happy with the buy.
$500 sounds like a great deal. Doesn't look too bad in the pictures. Nothing really stood out.
