For last couple of days since winter really picked up, every morning I start the car (2007 M35X) the breaks are just jammed
Regards
Ajuer
Don't worry! It happened to me too, it was after I washed the car and parked it right away in the cold , therefore it allowed some rust and maybe ice to accumulate on the rotors and basically merging the brake pads with it. I'm sure that in your case it happened after some wet conditions or snow driving, and afterwards parked overnight (most probably cold), the snow or water melted and dried on the rotors building up some rust and ice. Nothing serious.ajuersood wrote:Good Morning Members,
For last couple of days since winter really picked up, every morning I start the car (2007 M35X) the breaks are just jammed![]()
. I have to press the breaks couple of times to get it to normal. I do have a problem with ABS as infiniti dealership told me the front two sensors are broken. Could it be that its because of ABS not working, confused as what could be the issue. Please help if anyone else had that issue and how to fix it.
Regards
Ajuer
