Q_SHIP wrote:Who has any idea how to load these? Are the struts supposed to come up on their own?
Falk is correct so is Jay. Hydro shock don't have free rebound as gas chaged shoks do!If you have callapced shock and you tru to pull rod out you should have considerable amount of resistance depending on the speed at which you're pulling it out! Valving in a hydro shock is designed to control flow of oil at various speeds (suspension travel) The higher the speed of rebound/collapce the more resistance is created (simple hydraulic rules). As to struts cartrige R+R , it should come out w/o any problems. Here is link
zerothread?id=132979Undo a nut and it will fall out!
You have T model, might be slightly different!
Cheers!
Modified by FarFetched at 1:15 AM 12/1/2006
Modified by FarFetched at 1:16 AM 12/1/2006
