Yes. 15psi on a 50-trim should net you about 330-350ish whp. It's when you start running 20+ psi on it when the 700+cc's get put to some use. If you plan to stick with 15psi as your limit on it (which by the way, is just about where that particular turbo starts to breathe) then you could get away with some 650s (even though the price is usually the same). And just an FYI, you can get a set of Delphi 650 or 750cc's off ebay for $285 shipped.burnout 180 wrote:Would the 700cc injectors be big enough to support 13-14 psi on this turbo?
I thought i was restricted to 15psi on stock internals. I origanally wanted to boost 20psi for drag competitions which are once a month and 10psi normally. But I won't have the money to buy pistons, rods ...etc. until the end of August 2006.But now that you pointed out that it is possible to run higher boost on stock internals with the right tuning i'm even in need for someone to help me get a tuned ecu for my set up.float_6969 wrote:Not nessicarily. Not if it's tuned correctly. They certainly wouldn't hurt though.
IIRC, Boost_Boy was putting 350whp down on an internally stock CA w/o any problems.
As long as you have enough fuel, a good intercooler, and proper tuning then no. Although I don't think I would want to run 20+ psi on standard 93 octane. As for power, I don't know as I would think the .48 housing would start to be a little restrictive on the top end, so maybe 380ish? Can't really speculate.burnout 180 wrote:So how much power would you estimate 20psi to be in terms of my future new turbo set up?
Also would 20psi on this turbo be prone to detonation?
15psi on a 50 trim will not yield you 330ish-350whp. If you used a .63 back housing, I'll be generous and give you 315ish-320whp and that's because of the big backhousing. If you add some cams, I may be more giving. But a stock CA18DET with T3/T4 with .48 back housing which excellent for fun around the streets and hellacious response at the track, at 15psi, I'll give you 290ish-310ish. My car with a very good dyno tuning and 20psi of boost put out 332 to the wheels on a stock CA18DET and T3/T4 with a .48 back housing and a .60 front housing. It now has cams, valve springs, port and polish, 880cc injectors, and a few other goodies as more boost being ran. Got the last event of the season coming up next Sunday, and I can get the new head back in time, I'll be taking it to the dyno for some more tuning some time this week.c-rad wrote:
Just a matter of experience... on my friend's SR who had a T3/T4 50-trim, he was running 850cc injectors and running 22 psi. He netted 445whp and still had a little bit of breathing room with the injectors. I believe the avcr said the duty cycle was at ~85%.
Sounds about spot-on with my last past. You're playing a dangerous game with those 550s and that turbo. No wonder you're leaning out! Your injectors are probably locking-up because 18psi is their max. I use to hit 107% duty cycle on my MSD 50 lb/hr squirters and the best I was able to muster-up out of those things were 312.5whp on 18psi of boost using T3/T04B stage 1 with .60 front and .63 backhousing. Hope you guys are taking notes from these posts. There are people on this forum who have actually been where you guys are trying to go, so you guys wanting more power take notes.CA19DET wrote:
i just dynoed 304whp at ~15psi a few weeks ago (maybe more) IIRC (stock block CA18DET no oil qsuirters) with a T3/T4 50trim .63 A/R Stage 3 wheel from turbonetics... (i got 260 cams too) i am running 550's and my AFR's are about 10.5-11 (rich) and there is more power to be made, but an intake manifold and leaning out the mixture would yeild a few more too..
20psi would be the max on 550's, at 18psi, we started leaning it out, but between the injectors reaching 90%, and the clutch starting to slip and some other small probelms like a hose clamp blowing off etc, we called it a day, i'll be going back to fine tune the car soon as i want to sell it and the faster it is the more WOW effect it has..
i thought it was making more power at 15psi, at 18psi it was making ~320 by 5000rpm but we shut it down as the injectors were maxing out and the clutch was slipping after a few 15psi runs..
Since you have T3 already, use it! Those little turbos are cool for some fun, but they are prone to be abused and cause problems down the road. You can use the SMIC, but of course the FMIC is much more efficient. If only you knew how high those intake temperatures get with those SMICs.kapower06 wrote:Hey dee just wondering what you think I should do once I get everything up and running correctly... Should I keep the stock turbo or keep my t3 super 60 ( .60/.48) and use that with a custom manifold? Im looking to get around 250-275 whp... Would it be worth it to keep the turbo then have to pay to have the piping fab'ed up or should I just sell my t3 turbo and get a Gti-r or s14 t28 along with some injectors? Also is my goal attainable using the ARC smic and metal piping? thanks again -Jake
