More transmission questions.......
Need4Speed
Car: Unique Cars, Sailing, Shooting sports
I have been searching thru all of the NICO posts regarding anything transmission related in the hopes of a solution besides R&R; this has led me to ask you all a question:
I have read that the first gen trannies have a series of cooling slots on the lower bellhousing, like this I believe.... IIII.
However on my 93's transmission I seem to have a square opening with a black steel mesh or screen in it.
Is this a 94+ transmission? Or am I misreading info.
Anybody have a picture of a 90-93 transmission and a 94-96 transmission to send me?
Just trying to determine if the transmission I have is original or newer.
Thanks,
Andy
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
My 94 transmission has this mesh on it... Its probably supposed to be black, but I think mine was just metal...
The opening (I THINK) is to drain the torque converter, as this couldnt provide any cooling...
Need4Speed
So where are these cooling slots that I read about?
-Andy
elwesso
2007 BMW M Coupe
Show me some posts that say these are cooling slots...
Ive seen about 3/4 of the transmission, and I cant recall anything looking like cooling slots..
The only thing that cools the transmission is the transmission COOLER, whihc you should have an aftermarket one of...
Need4Speed
Man...you're gonna make me dig thru all of that again....... :rolleyes
I'll find it again.........
-Andy
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
AGM wrote:The way to identify an X65 is by it having one half a dozen slots in the bellhousing for ventalation as opposed to the X79 having just one large one.
AGM
The Search button is your friend!
Need4Speed
Thank you Brian.... :D
So am I correct in saying that it looks like I've got a X79 transmission.
I wonder if this the original then......Hmmmmmmmmm
-Andy
AGM
Is the transmission in the car? If so a good way to tell which transmission you have without pulling it out to read the sticker on top of the housing is a follows.
There is a metal tag attached to the rear mounting point that you should be able to remove/read by just removing the rear (right hand) mounting bolt from memory. Hope this is helpful.
Regards
AGM
Need4Speed
I'll take a look......Thanks.
-Andy
