Clawhammer »
https://forums.nicoclub.com/clawhammer-u53050.html
Thu Apr 24, 2008 8:24 am
So a couple weeks ago I got the bolts fixed on my tanny, and got the new front bearing cover in and such. New ACT 6 puck, etc. A good like 900$ at the transmission shop. Since then it's still made this slight rattling which after reading around I thought it was my B&M shorty, but then it started getting worse.
As I coast through 2800-2300 RPM it starts making this terrible rattling-griding noise. Perfect above and below though.
Took it back to the shop and they diagnosed it as the roller bearing on the input shaft. They're not going to charge me for removing the transmission again because they just did. They saw the broken bearing retainer and figured that was the prob. So now...
Do I want to spend hundreds of dollars to fix this problem? Or just drive this thing till it explodes and then swap the bellhousing on a KA transmission and throw that in? I can buy KA transmission's in tampa for 50-100 bucks all day long.
What would you do? How bad could this actually be? Is it possible I could drive on this thing for years without catastrophic failure or should I get this fixed ASAP?
