evildky »
https://forums.nicoclub.com/evildky-u13100.html
Thu Jul 26, 2007 6:13 am
id the timing belt is partially off there si some sort of problem, you need to pull the timing belt cover and find out why the best isn't on all the way and verify it is in correct time, if the belt is coming off, most likely someone damaged, lost or installed backwards the slinger on the crank pulley when they did the last belt, in any event you need to take it apart and fix it
