SixGuns »
https://forums.nicoclub.com/sixguns-u95290.html
Tue Dec 09, 2008 10:54 pm
Thanks for the replies, fueler....(why the hell are you awake at almost 1am?)...as far as the camber, I was actually planning to fab up some custom upper and lower A arms....mainly because of the length that would be involved in the new CV axle, on compression of the suspension, and the tire moving upwards, with stock A arms, you're going to crush the axle, bind something, or just break it...so, keeping everything even is the key there, I'd say....And for the harshness....well, yeah...it's not really much taller of a spring, just a different spring rate, so it doesn't sag as much under load, therefore sitting the vehicle higher...trick there is longer springs, same spring rate as stock, maybe a little tighter....almost factory ride, just taller....at least, that's what I'm hoping for....don't get me wrong, I'm not saying I know exactly what to expect, and I appreciate your giving me the heads up....I just think it would work wonderfully, with enough planning and a little bit of fabrication....
